Tilt Trim Socket
spiderhaze227
Does anybody know where I can get the socket I need to open the pistons on my tilt trim, maybe buy used (cheap) Imean if Im gonna use the wrench once, plust the oil line tube locate under the tilt/ trim. I have an 1987 88 spl
mikesea
Re: Tilt Trim Socket
look at the listings for parts on ebay,or,call around to some outboard shops ,for a used one,they are available,as for the tool,you can get a spanner wrench,I have seen butchers do it with pipe wrenches ,even using a punch and hammer,i dont suggest it ,but seen it.if you have some mechanical ability,you can make one ,drill your holes in a piece of metal stock,cut a slot to allow for the pistin ram,use 1/4 inch bolts and cut the heads off for the grabbers
