Grease Question, compatibility of different greases?
crazy charlie
Hi guys, I grease everything with Wallyworld marine and wheel bearing green grease. Gimbal zero, bell housing zerk etc. grease gun broke today and the only other grease gun I have is filled with Lucas Red and tacky. I am aprenhesive to pump the red and tacky into the green marine grease zerks. Do I wait till I get a new gun to keep the green grease going or should I pump some red and tacky into the zerks and wait for a new grease gun for Christmas ? Just concerned about compatibility. BTW my wife would really love to get me an easy gift like a grease gun ....would make her gift list easier for sure..lol
froggy1150
Ensign
I am going to assume wallyworld is a nlgi2?
I dont like to mix grease because it's hard to judge what is compatible. The red is a synthetic nlgi2 with additives. Is a $5 grease gun worth your time and $$$?
Might be ok
jlh3rd
NLG ratings don’t define compatibility.
”BASE” determines compatibility.
lithium…aluminum complex…..calcium…others are all bases.
some different bases can mix, supposedly. There are compatibility charts but I’ve also heard those charts can be wrong.
so, do diligent research.
Gee, wait for the new grease gun and continue with the Wallyworld stuff. I think the red and tacky is a lot heavier than the marine grease you have been using.
Heavier grease is not always better, and it does not flow as well, and that red and tacky stuff is really stiff. If you had a piece of road work machinery with really loose bushings or an army tank that needed grease, the red tacky stuff might be good.
Scott06
They are both lithium complex greases and compatible wouldn’t hesitate to mix them. For this or other grease compatibility concerns you can look up what type of greases they are and if they are compatible types.
mike_i
Do a search for a grease compatibility chart.
Texasmark
I too have read about different based greases may be incombatable......so I always wondered what difference does it make if grease A and grease B don't homogenize????? They are both lubricating the surfaces.... jam up against each other, unless there is some kind of difference in the chemistry where one changes state due to some environmental difference to which it wasn't designed......and what does it do, get hard, get runny and flow out of the area?
There are different types of grease. My father had a can of grease with some sort of fibers embedded in it. It was very stiff compared to the lithium grease of that period. I would not use that kind of grease now, but back then (mid 60s), it was used.
Scott06
yes The grease basically comes apart and separates back to its previous components oil and a carrier/ binder That thickness it to grease. I think one or two of the combos thicken it but one would have to read up on it
Lou C
I think that's the stuff I used to use in the '70s when I had my air cooled VWs, as I recall it was nasty smelly stuff (Castrol or Quaker State?) Yellow stuff.
Lou C
A couple of OEM trailer companies use Red & Tacky, I know for sure that Venture does and so does Coyote trailers. My brother had a 2021 Venture and has a 2023 Coyote now both had Red & Tacky. It's a lithium complex grease.
JimS123
Years ago I had to repack my wheel bearings just before a long vacation trip. On hand I had two cans from different manufacturers. Neither had enough left to do the tandem trailer. I mixed them together.
I stopped at a trailer stop to have lunch and check the tires and bearing temps. All 4 were leaking. The grease was coming out like water and spraying all over the wheels and side of the boat.
I know that you can check specs to find out what is compatible. But I learned my lesson. I will never mix again...period. I throw out an old can and buy new. Saving a few bucks ain't worth it.
Texasmark
That was old style automotive front wheel bearing grease......I used it back in the '50's and 60's. When manufacturing designs changed and the fiber was taken out of the cup grease you bought in the auto parts store, I had a hard time mentally adjusting to it!
You didn't put this in a grease gun to lubricate zerks!
I think the fiber grease would simply clog the grease gun.....
Lou C
When I replaced my trailer axle in 2021 I started using Lucas Marine grease (blue stuff) it is a calcium sulfonate base grease which appears to be a bit better in wear and heat resistance than most lithium complex base greases. The Red & Tacky (red) is a lithium complex base grease.
With the gimble bearing and the u joints on my I/O I used to use Pennzoil marine grease which I think was a lithium complex base grease, because the Lucas Marine was compatible with it, I switched over and have not had any problems, I would have continued with the Pennzoil but could no longer find it. That gimble bearing was last replaced in 2005 and the ujoints, I have never had to replace, owned that boat 24 years.
airshot
Remember that well. That grease was used for wheel bearing, the fiber was to keep the grease in place. Used that stuff when I first learned to pack wheel bearings....about 65 years back....
airshot
Not sure what happens when different creases are mixed but did have an experience about 20 or so years back. Had a wheel bearing come apart on me and ended up finding the grease had become watery and just ran out.
After some research I read that certain creases when combined turned to a runny liquid. When pulling the old bearing the grease was very runny like water and there was very little left. Yes, I had ran out of my usual grease and used some my son had left in the garage. Both were labeled as wheel bearing grease and labeled as compatible with other grease ! This did jot happen over night, but over a few weeks bit a month the mixture turned into a watery liquid like oil.
Lou C
From my circa 1972 VW Idiot book, that is the smudge of the nasty yellow smelly fibrous grease I think it was Quaker State….
