Grease Question, compatibility of different greases?
crazy charlie
Hi guys, I grease everything with Wallyworld marine and wheel bearing green grease. Gimbal zero, bell housing zerk etc. grease gun broke today and the only other grease gun I have is filled with Lucas Red and tacky. I am aprenhesive to pump the red and tacky into the green marine grease zerks. Do I wait till I get a new gun to keep the green grease going or should I pump some red and tacky into the zerks and wait for a new grease gun for Christmas ? Just concerned about compatibility. BTW my wife would really love to get me an easy gift like a grease gun ....would make her gift list easier for sure..lol
froggy1150
Ensign
I am going to assume wallyworld is a nlgi2?
I dont like to mix grease because it's hard to judge what is compatible. The red is a synthetic nlgi2 with additives. Is a $5 grease gun worth your time and $$$?
Might be ok
jlh3rd
NLG ratings don’t define compatibility.
”BASE” determines compatibility.
lithium…aluminum complex…..calcium…others are all bases.
some different bases can mix, supposedly. There are compatibility charts but I’ve also heard those charts can be wrong.
so, do diligent research.
Gee, wait for the new grease gun and continue with the Wallyworld stuff. I think the red and tacky is a lot heavier than the marine grease you have been using.
Heavier grease is not always better, and it does not flow as well, and that red and tacky stuff is really stiff. If you had a piece of road work machinery with really loose bushings or an army tank that needed grease, the red tacky stuff might be good.
Scott06
They are both lithium complex greases and compatible wouldn’t hesitate to mix them. For this or other grease compatibility concerns you can look up what type of greases they are and if they are compatible types.
mike_i
Do a search for a grease compatibility chart.
