1993 Crownline 196 BR fuel tank access port gasket
keviwe
I just bought a 1993 Crownline 196 BR. It's been stored for years so I plan to remove the fuel tank access cover to siphon out all gas. I will replace the access cover gasket. This is a 40 gallon tank.
Does anyone know wat company made this gas tank so I can order the correct access cover GASKET
keviwe
Unfortunately, I store this boat in another state so I can't check the label on the tank, until I get out there to start working on it. I'll have a week to get it running and no time to wait for on-line parts to be delivered. I might have to just buy (from the link you sent) and hope for the best.
tpenfield
You can also siphon (pump actually) from the main fuel line . . . no need to remove the sender, unless you want some visual of the tank internals.
