2001 yamaha 150 vmax
Chuck4741444
Im replacing the high pressure fuel pump on the vapor separate, the pump is sitting 90 degrees off to line up with the studs everything else fits. Also what are the molded pcs that slid over the studs on top called, I need the o rings, the didn't come with the kit.
boscoe99
There are several different 150 VMAX models. Carburetted, conventional EFI and HPDI models.
Sounds like you might have a VX150TLRX model. Is that correct?
Chuck4741444
Fuel injection, the orings are for the electrical separator on to of the vapor housing
Chuck4741444
The model number is not readable, i do have the numbers on the title, its an ox66
