- Jul 23, 2011
- 53,336
Sew in some heat tapeI’m going to make winter covers![]()
Yes, I used 4 yards of 54" wide material for each engine . . . a lot more than I was initially thinking. I also made them a bit bigger than they needed to be, figuring it would be easier to 'snug' them up if needed.I have 2 covers shipped with my old chap but they were to small for the Mercs, and no way would fits yours, most likely were for Yam's. Sooner or later I'll find a use for them
Motors weight 800 lbs. each . . . I don't think they would fit in the garage. Where they are is where they stayNice covers, but if you really loved your motors you would keep them in the garage ...![]()
Pole barn.Motors weight 800 lbs. each . . . I don't think they would fit in the garage. Where they are is where they stay![]()
Not sure they allow those where Ted livesPole barn.
Fair enough. Also one of the many reasons I'm picking a place to disappear to when I can...Not sure they allow those where Ted lives
Pole barn.
Probably, with enough land, a barn could be built . . . but I'm maxed out on what the house/land can do.Not sure they allow those where Ted lives
Was only kidding. Dad built his whole pole barn for a year rent at that rate. I can't ever justify paying for storage of something at a rate like that. Just ain't worth it. I will note, my town rates lot coverage different for pole barns because they aren't considered dwellings or permanent structures. Otherwise we'd be over lot coverage too for development in our area.Probably, with enough land, a barn could be built . . . but I'm maxed out on what the house/land can do.
There is a place right near the re-power shop that is called "Boat Loft Condominiums" . . . For a mere $200K you can own a high-bay unit to store your boat. You can also rent similar spaces for $2,400/month (+/-).
I think I'm good where the boat is . . . in my driveway . . . $0 incremental cost.![]()
