Michael-Chgowiz
- Aug 27, 2026
- 14
Hi everyone. New to outboards, but not afraid to wrench around, used to race stock cars about 20 years ago around local short tracks and was pretty much my own mechanic.
I've got an inherited 1986 Johnson 30hp (J30TELCDM) and I'm trying to chase down why I've got a rough idle at just below midpoint, and it dies if I go any lower. I've got a list of things I've done carb/fuel pump/fuel filter/link&sync-wise, so now I'm looking at other possibilities.
Two questions:
1. Are the vacuum lines coming off the choke/primer and going into the T to the carb/engine supposed to look like this, and be without tie strap clamps on them? I've sprayed carb cleaner around them, especially around the one that connects to the choke/primer and it kills the engine immediately. Makes me think they're leaky and possibly causing my problem?
2. The instructions in the Clymers for my engine for throttle control rod adjustment - I don't think I'm doing it right.
"With the shift lever in forward gear, the throttle lever should touch it's stop" - what do they mean by that? I don't see anything move or stop when I shift to forward, aside from the shifter. Nothing moves around the throttle that I see. What should I be seeing?
It tells me to loosen the collar on this rod then "push the rod to a full open position. position collar in contact with nylon pivot block and tighten."
I've tried to mess with this adjustment, but it seems to cause a lot more issues with the cam roller being shoved too far out from the cam and that doesn't seem right. I just adjusted it back to where the roller is just touching the cam between the dog ears like it should be. But then I'm pretty sure I'm not doing this right.
See below for what I did for #2.
Thank you!
Two questions:
Thank you!
