What is this?
Skidude17
I connected my batteries to a jump box after the boat was sitting for awhile, and the starter was working fine initially. Then it just clicked like the battery was low. I checked the voltage and it was 12.8 when key not turned and 12.6 when key turned. I connected my remote starter switch, and the starter worked fine again. The only thing I could find out of place was the item in the pictures behind the gauge cluster. Does anybody know what this is? Could it be what’s stopping me from getting a good connection to my starter?
dingbat
Looks like a switch contact. Guessing the ignition switch failed
Skidude17
I’m having a hard time finding anything called a switch contact to purchase. Is that something I could buy by itself, or would I need a whole new ignition switch?
dingbat
Switch contacts are not replaceable.
You need a new ignition switch.
Recommend doing some basic troubleshooting before breaking out the "Parts Cannon"
Skidude17
Whatever that is, it’s definitely burned up. I’d like to replace it, but I don’t know what it’s for, so I don’t know what to troubleshoot.
Skidude17
Thanks for the comments folks. Turns out it is the connection for my 12V cigarette lighter adapter.
