Yamaha 9.9 troubles
matt167
My new boat ( 1989 Sylvan offshore ) came with a 2002 Yamaha 9.9 ( T9.9 ELRA high thrust ). Couple issues. It is pumping water but not as good as it should. I put a new pump in it and the pump impeller that was in it was good. The passage is clear. Also it won’t start unless it’s manually choked briefly so I don’t think the primer system is working. I think it’s a pretty high hour motor. Debating repair vs replacement as 9.9’s aren’t terribly expensive in boat terms
boscoe99
What are you doing to manually choke the motor?
That model does not have a mechanically activated choke plate. It uses a Yamaha PrimeStart system. Automatic fuel enrichment.
If the motor is not over heating then the water pump flow is more than sufficient, no matter what amount comes out the telltale fitting.
matt167
Literally cover the carb with my hand for a second and it pops off. I know it’s a primer system. I suspect it’s not working. As for the telltale. It dribbles and spits. It’s not overheating but I know it’s not right either. Also throws a bit of blue smoke at startup which is what makes me think high hours.
matt167
Not sure as I haven’t checked it. I really don’t think it’s down on compression as it does actually run fine and has plenty of power. I just don’t know the break point of where it makes sense to repair vs replace. I’d have no problem putting a brand new DF9.9A on the boat vs replacement if it was going to cost $1,000 to bring it back to life… primer solenoid alone is $100 provided that’s the starting problem
matt167
I guess it might make sense that it’s been cooked as the rings could be hurt and still run well enough. I don’t have high hopes I guess. I may drop it off at a local shop for a damage report but I won’t be going into any powerhead work. Not worth it
99yam40
compression is easy to check, and a carb clean & pulling stat and flushing the cooling system with something like Ridlym marine descaler is not that hard either
matt167
I would tend to agree 100%. I keep the boat at a storage facility since my yard is a postage stamp.. I can trailer it to my FIL’s for work but I also work full time leaving only weekends and summer is only so long. Paying for a diag may be cheap in the long run
matt167
The only thing I can think of on the cheap is that if it is condemned, I have a 1986ish Johnson 20hp w/ remote control that I bought for a chugger boat project. It’ll probably need a carb clean and an impeller but it was a solid runner. It’s been on a stand in dry storage since about 2019.
matt167
Is $1k a fair price for one of these motors as a low hour pretty minty and mint running one?
Some 9.9 /15 HP motors may have been leased by fishing lodges.---Returned to factory for a new hood and cosmetic touch up.-----Sold at some dealerships,----It is a " buyer beware " sometimes.
boscoe99
Yams are not the best pissers known to man.
What are using to determine a good **** from a not so good ****?
If the motor is not having an excessive temperature event I think your cooling system is just fine.
Aging Primestart systems are known to make a motor be hard to start when cold.
matt167
The one I have just has many signs of being a worn out high hour motor when you look close. I missed it when I bought it truthfully as once running it does run good. I don’t have time to go through it myself and the local marine repair shop would figure $600 to go through it, and then you factor in a cracked cowl, torn gasket, starter gear is nearly worn out completely. bad paint and a slight oil leak at the base of the powerhead. To fix all those issues I’d have spent close to a new motor.
matt167
I’m going to go for it. I really wanted another 4 stroke FI Suzuki but it’s not in the cards this year with the boat purchase and it may not be next year so this should plug and play onto my controls and away I’ll go. Hang onto the old motor for parts
matt167
Forgot to update this. Drove to get the new old 9.9 ( T9.9 ELRY ) and it is for sure a low hour non commercial use motor. Sold by the dealer I bought it from originally.
Had a slight whoopsie that the guy that helped me load it must have missed as well. But nothing major. Transported on the wrong side so I’ll have to pull plugs and get oil out of everywhere it shouldn’t be but it’s a really nice motor.
matt167
I just got the motor hung on my kicker bracket. It didn’t come with a control harness so I had to use the ELRA harness from the old motor: The new (ELRY) motor has an extra male bullet connector that is connected to the grounds. I’ve hooked it all up it’s just that dangling. All other connectors match up… can I simply tape the connector off? I’m thinking that motor was set up for controls where the ground hooked to a bullet connector vs now it’s directly connected as an updated design since my ‘old’ motor is actually a bit newer though being 95% identical.
