1995 Crownline 202BR Restore
beta
On the pedestal seats would they not be bolted thru with a t nut? No expert, pure ignorance here.
The bases are 2 - 3/4" marine plywood (left overs from my stringers) glued together. I'm going to use 1.5" screws going down into the base and put 5200 on them. The holes in the pedestal are 3/8" so there will be 6 heavy duty screws holding it down. I thought about doing the bolt through but decided the screws would be more than enough.
The original design had a steel plate under the deck with bolts coming up from under the plate. It was heavy duty but those holes in the deck catch up with you eventually, at least in the case of this boat it did.
Pmt133
I thought about doing something similar at first. But I was having nightmares about screwing it up and having to do a major transom fix so I dropped the $25 on the guide.
I only had a half inch bit on hand so I prayed when I did it. Ran a bur through one hole to clean it slightly. But if the assembly slid all the way on by hand, I figured it was good. Knock on wood, no issues... yet. :LOL:
beta
Dry fitting the gimbal housing and the transom plate are coming up on the agenda. New gaskets are on their way. Fingers crossed...
I was also looking at the drain plug. It appears there is some kind of sealing material was around it but it wasn't a gasket of any kind. Is it just sealed with 5200? or something like permatex form a gasket sealant?
Pmt133
More than likely for a brass garboard. Silicon, 5200,4200, boat life... anything they had open at the time most likely.
beta
Got all the floor mounted items for seat pedestals, battery, hydro pump, etc glassed in over the weekend.
I've decided to use 1" square aluminum extrusions to build a frame for the sidewalls next to the engine and the frame that holds up the cushioned hatch above the engine compartment. To secure the bottom, I added a 1" high piece of the 3/4" plywood to the deck. The extrusion will go just to the inside of the wood piece. I'll screw through the wood and into the extrusion horizontally to secure the bottom.
beta
Last night was gel coat time. Covered everything except the bilge and transom which I'll do next. Did 3 coats, mostly with a 9" roller. There are a couple of spots I'm not 100% happy with which I'll sand and touch up when I do the bilge. Overall, pleased with the outcome. Plan is to put SeaDek on floor. Not sure if I'm going to do anything more on the side walls right now. My plan is to redo the side panels (and other upholstery work) during the next off-season so will probably just leave the walls as-is with the gel coat for now.
