1988 Rogue 2420
Currently making a list of things to address that I noticed when getting ready to head out
Recaulk the rubrail with something other than 3M products
Re-attach the port side headliner in the cabin
Finish the cabin closet
Add the water tank and transom shower
Get new head unit
Get new portable potty or just a new upper tank. Heat cracks in tank
3D print new hatch latches because the parts are NLA
Finish painting spare drive and swap to address corrosion starting on primary drive
Replace rollers on trailer
Buff the boat and wax it
Add scuff plate to bow
starboard side head liner has come down. so now redoing the whole headliner
the two solid state relays that power the house loads are failing. they are 100 amp mounted to heat sinks with heat sink grease. both drop voltage at over 10 amps. they are only 6 years old and have less than 100 hours on them
and people wonder why I hate electronics.
seriously considering a pair of trombetta bear contactors. big a$$ coil pulling in big chunk of iron making contacts..... other than the coil hold current of 0.5 amps. they are bulletproof.
