2002 Johnson Bombardier 90hp Outboard
Snowfish
Potentially buying a fishing boat with a 2002 Johnson Bombardier 90hp Outboard.
Looking for a second opinion since I have no experience with Bombardier outboards.
Only experience is with SkiDoo snowmobiles that use Isoflex in the crank bearings.
Are the outboards the same? If they are, I don't want it.
If not, any experiences or insights, about this engine, would be greatly appreciated.
Bombardier took over Johnson and Evinrude.------So that engine is the same as a 1995 model Johnson or Evinrude V-4 with a 60 degree block.----I do not know what an Isoflex bearing is ?-----The bearings in the outboards by them are very , very good quality !!
There are no bearings on that JOHNSON that need attention from the owner.------Quality bearings are all inside the engine and get lubrication from oil that is mixed into the fuel.----Oil is mixed by automatic injection.----Or by mixing at 50:1 if oil injection system is bypassed.
Snowfish
Thanks. Hope to possibly pick up this week end. Here's the motor.
oldboat1
18 yr old motor would be pretty new to me -- but still has an old impeller if not recently changed. Change it out if any uncertainty.
Newbie@boats
Totally off topic, as I’ve done a few sleds with the isoflex grease in the crank bearings in the bottom ends and put thousands of miles on them hassle free....why would you that steer you away?
Crosbyman
well…..it is 18 years old normal caution needed here
before the bucks leave your wallet …why not…
1- get compression tested to confirm none of the cyl. are way off the rest … probably above 120lbs each ...get the specs ...a bad cyl may indicate cyl scoring, bad rings, bad head gasket etc... the usual stuff
2- Not certain it may be a FICHT with pre E-TEC EMM which should looked at by a certified mechanic who "wants to look at it" (check for error codes- log for anything suspect)
3- Can you try it…? start it see if it runs ok can you go for a good ride at WOT idles down ok?
4- the power distribution panel has a history of cold solder joints...not a show stopper but needs to be considered down the road if you have problems ( any bad solder joints can be simply resoldered ..easy fix apparently …)
5- inspect gearcase oil for contamination (water)
rig look clean, well kept as well as the engine… good sign
if it runs like my 2005 ETEC .... great stuff :)
For 2002 Johnson only offered the simple carbureted 90 HP as a carbureted 60 degree V-4 model.
Crosbyman
yep !!! evinrudes were injected :cower:
Johnson'S stiil had carbs....:facepalm: according to that marine parts diagram ... place
less things to go bad :)
thanks for pointing it out :sorry:
oldboat1
Had some experience over the last 20 yrs repairing solder joints on old Mercedes circuit boards (climate control in particular). It's one of those fixes that might be overlooked -- simple fix, that can be the difference between a system failing and running like it was meant to do. The catch is that you need to be able to recognize that as the problem, or you can end up spending big $$$$. Getting a mechanic's inspection on the front end is good advice.
Snowfish
Been having a blast, with this rig, for a long time.
Until now.
Coming into the landing the motor quite like the key was turned off.
Got a couple pops, and one short rev, upon attempting re-start.
Have verified fuel pump is good. Good flow going to carburetors.
Has spark, but appears weak.
Checked kill switch tether. Functional.
Spark plugs were very dirty. Replace with new NGK's
Inspected wires & connections hoping to find that "ah ha!" moment, All solid & intact. At least on the surface.
Got a couple pops, but still will not start.
Since all cylinders quite firing, I have a sinking feeling the Optical Ignition Module has failed.
2002 Johnson 90hp carburated.
VRO oil injection
Seasonal maintenance includes fresh spark plugs, general under cowl inspection for loose or chaffed wires, clean, and grease.
Engine has ran perfectly until now. No "hints" that something was going wrong.
Before I start replacing parts, I would appreciate any insights or recommendations you may have.
A service manual would help you check out the ign system. Marineengine used to sell factory service manuals. You would need an engine model number to get the exact one for your motor.
Snowfish
Thanks for the fast replies.
Sorry to resurrect My old thread. Just thought keeping it together would be best. Will make new thread even if I'm just updating My previous encounters.
I have the manual already downloaded.
Was hoping someone here has had a similar situation as mine.
Feel free to chime in if you have any insights or ideas.
