1977 1150 Coil Replacement Options
kck8385
I need to replace the coil on my 1977 Merc 1150. The current Merc number is 332-4985T 2. I can not find a Sierra coil that crosses with that number. Sierra 18-5186 crosses with Merc 339- numbers. Has anyone used the Sierra 18-5186 on an inline 6 motor? If not I'll bit the bullet and purchase the OEM.
Thanks,
Kevin
Sierra should make a coil for your motor. You need to look a bit more.
Are you sure the coil is bad? They last a real long time....
kck8385
Chris,
I ended up calling Sierra's technical department yesterday and was told they do not make a coil that crosses with mine. He looked up the Mercury number as well as my motor and said it was a no go. I ended up buying the Mercury coil. The Sierra number I gave above looks just like it but he said it was not a replacement for mine.
My coil readings were bad and it is cracked. I had the cowl off Sunday while it was idling in a tub and I guess the wind was blowing just right because I heard a random electrical clicking noise. When it happened 3 or 4 clicks in a row the motor would stumble. I thought it was coming from the coil area so I pulled it and found what you see in the pictures. The magnet is cracked all over. The triangular piece fell out when I pulled the rubber off. As you can see the plastic above the magnet is cracked also.
I will update my previous posts if this solves my 2 year long random electrical shutting off issue and more recent bogging at high RPM's.
Thanks,
Kevin
OK, well you got the defective coil. It had to happen to someone.
If memory serves me, Sierra did make a coil some years ago. Maybe they discontinued it. The ;last distributor Merc was manufactured in 1979, and the phase out of the distributor ign was well underway by 1976, in the inline 4 cylinder models.
Glad you found that issue. I new coil should surely help with your issue,
BTW CDI Electronics still makes ign components for your motor.
kck8385
Yea I seem go be lucky that way. Thanks for the help Chris.
Kevin
jimmbo
I wonder if copious amounts of non conducting epoxy would fix a cracked coil?
