Nucknoilerfan
Thread starter- Joined
- Nov 6, 2003
- 64
I have a 1980 7.5hp Gamefisher that appears to be in okay shape. The problem with it is a reliabity issue. Sometimes I go out to the lake and the thing starts and runs pretty good pushing my 12' Aluminum around resonably well. Othertimes I get to the lake and yank and yank till sweat is running and my fuse is shrinking. There has also been times when it starts fine and I motor out to my fishing spot, lay anchor for a couple of hours and then the thing doesn't want to start. I've replaced the fuel pump, rebuilt the carb, replaced the plugs numerous times and had a buddy replace the head gasket. As far as I can tell the compression seems fine but I'm at a loss to think of what the problem could be. Do I have a professional look at it and fix it or do I spend around $400 and try to find a used 9.9 merc or something. This one only cost me about $100 from a friend but I'm not quite sure if that was a deal or not.
