ebbtide176
Thread starter- Joined
- Jan 22, 2002
- 2,289
I am trying to get model# and serial# from this old motor of mine. i think it was made 55-57, not sure. i found a lot of diff#'s on it, and wondered if some great minds here might know what is what...
<br /><br />2924 >tag on top of clamp<br />S-1873 >front eng block<br />064 >top eng block<br />1791623 >back eng block<br />3835-189 >rt side eng<br />3835-1817 >lf side end,reed cover?<br />139-1883 >head,rear eng<br />carter N >carb type<br /><br />it was hard to make out some #'s. i am interested in a fuel pump kit, if possible. it bolts to rt side, not internal, and runs off hose from eng block, 1 line to ext tank, 1 to carb. <br /><br />i bought it from an old marine tech several yrs ago, and he had 'gone over it', and repainted the block. it ran good, but always died out at WOT unless you pumped the bulb. all the fuel hoses were new, along with bulb, i just got a tank with the single line clip. i read back thru here on the probs, and will ck the float level, bowl, jets and maybe look in the pump, if able.<br /><br />one other thing; it has upper, lower adjstmt knobs plus the choke, and i always forget which is which... isn't the top (to mid carb) low speed idle, and bottom (to bowl) the hi speed adjst?
