Repair Crankshaft - Yamaha 90hp
liamtovey
I have a 3 cylinder yamaha 90hp outboard (1998). One of the oil injection<br />hoses came loose during transit, and the 2nd cylinder caused the engine to<br />overheat. The result is a crankshaft with half the centre journal a bit<br />scuffed. I'm told by a mechanic that I would be crazy to use the motor again<br />without replacing the crankshaft ($1200). It amazes me that I cannot find<br />anywhere in Australia who can repair a crankshaft !<br /><br />Is it possible to get some sort of two part hardened metal sleeve that can<br />be fitted over the jounal once it has been ground down to restore it to it's<br />original size ? How deep is the "Hardening" on the crankshaft ? How else are<br />crankshafts repaired ?<br /><br />Thanks for your assistance<br /><br />Liam
jim dozier
Re: Repair Crankshaft - Yamaha 90hp
Check Ebay, maybe somebody will part out a decent crank. I don't think they make oversized roller bearings for ground down cranks on outboards, I could be wrong.
Paul Moir
NEECA does individual journal repairs. They grind the crank slightly and set you up with oversized bearings.<br />I don't know if it would be worthwhile to ship your crank all the way from Australia though.
rodbolt
hello <br /> most any good motor cycle shop should have the tooling to repair that crank. ackermann marine here in the states does mine. the crankpins and cheeks are pressed together.<br /> good luck and keep posting
NEECAPRS
Itovey2: Since you can see the scuffed journal, you presumeably have the one piece crankshaft. The hardness goes all the way through minus any deep burning that continued running may have caused. How long did you go before shutting it down? "Scuffing" doesn't sound serious at all.<br /><br />You can beat the $1200 price by a lot. It's a long way over here, but, we'll repair it, provide the bearing, and refinish the rod of your choice for only $240. If interested, we're at NEECAPRECISIONS.COM
