My 1988 Yamaha 115 recently was not running, because of a kill switch problem. I posted the topic and thanks to the guys here, I fixed it. I had to disconnect the white killl switch wire from the CDI unit in the motor. On ce I did that the motor started and ran. <br /><br />The only problem was when I went to shut the motor off, nothing happened, it kept running. The ignition switch started the motor but did not turn it off. Some one please help I was so close to putting in the water.
