FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
1984 35,s/n 6490024. Am doing a carb cleaning and kit, was wondering if anyone would have the float setting and procedure for making adjustment. Thanks in advance
The simplist way to set float leve on the side bowl carbs is to turnn the top upside down an bend the inner arm so the other arm is level from pin to pin
Before you button up the carb, tip it upside down and gently blow into the fuel inlet fitting. If air passes, the needle and seat are not seating. If not, you are good to go.
