Running on mufffs
Plainsman
I have never run my motor on muffs. Sould the hose be just slightley turned on so the water doesn't escape the muffs? Or should it be turned up some so it does a little?<br />TIA<br />Eric
gmb
Re: Running on mufffs
turn the hose all the way on. You need full pressure
B.M.W II
Turn the hose all the way on so you don't run it hot. The water pump will suck up the water it needs.
tashasdaddy
all the way on, and prepare to get your feet wet. i put one of those little stop **** valves on the hose, next to the muff. this way you don't flood the yard. you can turn the water on and off right there.
Silvertip
I take issue with full house pressure when running on muffs. Think about it. Most home city water systems can run 60 - 80 PSI. Granted, the muffs generally let water escape but at what pressure? The internal shaft seals are not designed to withstand those pressures. Run enough water that you get a solid tell-tale stream and don't rev the engine higher than 2500 RPM and you'll be just fine. Most outboards idle at about 10 PSI water pressure so 60 - 80 PSI does you no good anyway.
rickdb1boat
Agreed. And by having the pressure real high, you risk the muffs pushing themselves off and thats never good....
tashasdaddy
sorry, i run mine all the way on, because i use irragation water off the well. much lower pressure than city water.
gungalunge
i was there yesterday . put the muffs on. i questioned will it work it did . let it run man give it the water , more is better
