Actual mph(speed) comparisons.Post your highest speed.
Status
Not open for further replies.
Michael Belcher
My 225 Mercury 2 stroke was recently rebuilt.Specifically,I had air getting in the fuel through some check valves and gaskets(new ones are neoprene-old were just rubber. My problem was the boat was slow to plane and just slow.Pitch on prop is stainless and 19. My boat is a 26ft. center console trying to hit 50mph.Please post your boats top speed so I can compare. Should I buy a 250hp or 300hp or am I good? specifically I'd like outboard comparisons.My top speed so far is 48mph with a 225hp motor on a 26ft. boat.
Kenny Bush
Re: Actual mph(speed) comparisons.Post your highest speed.
I think your are in the max zone. You may have to go too twins to get up there. A 300 verado may get you there but it's expensive. My 25' Fountain CC had a single 200 and went 46-48 MPH. Put a 225 EFI on and got to 55 empty, but you could not hardly get on plane with 4 fisherman and equipment. I also propped it out and found the vented 19 to be the best, and my fountain is extremely light. My Chris Craft Scorpion CC, 23' has a 3.4L 300 merc, and it moves 55-60 loaded up. I recently put a bracket on the fountain and I am putting 2 225 EFI's on it. I am hoping for 60-65 loaded, with 70+ empty. My calculations should put me in the Zone. Another factor is deadrise.... What is yours, and what type of hull is it?? Is it heavy/light??
Michael Belcher
My hull is light,2700 lbs. dry with a 23 1/2 degree deadrise.Should I be getting more than 48mph out of this motor? Is there anything I, as a non-mechanic, can do to increase performance? I'm using synthetic blend oil(pennzoil), I flush the motor each time, I put new plugs in every 6 months, I open my Racor filter each usage to drain any water or sludge, and my prop is clean and straight at 19 pitch. Thanks for the reply.
verojoe27
21 foot center console (hull=2,400 lbs), with a Mercury150 Black Max. and 17 pitch SS prop= GPS 42mph at 5800 rpm
Kenny Bush
Scarab1, I believe you are at the best you be with that motor. That is a pretty deep v, and takes a little more HP to keep it up on the keel. You can do what I did, and switch to an EFI which will give you more maximum RPM's, or go to a bigger motor all together. You are doing all the right stuff in regards to maintenance, but you need more RPM's or a bigger motor (so you can prop up to a 21' or 23').
DoctorCAD
18' Ebbtide Fish-n-ski 150 Black Max SS prop<br />63 MPH GPS verified. Scary at that speed.
Michael Belcher
Thanks- I'm satisfied and will finally enjoy the boat! Whew!
buck9475
1993 proline 22' cuddy cabin, Merc 200 efi, 17p vented mirage, 3 people t-top,full gas tank, 49 mph 5,700 rpms, gps cert.
cbavier
1986 Four Winns Horizon 190 , V-6 Mercruiser, Alpha 1 , 38 MPH GPS certified at 4800 RPM
Harker
14.5 Devlin Black Brant 2 home made...98 Mariner 25hp with 13 pitch prop...29mph GPS with me and my 100lb lab.
My 1974 Starcraft Islander 221, 4.3LX, 1.65:1 Alpha 1, Torque-Shift Prop 11"/20",.......
In Full Fishing/ Trolling dress will pull 42mph,gps, at 4900rpms in Freshwater,.......
And 53mph,gps, in Saltwater........
deejaycee_2000
21 ft raven speedboat with 475hp johnson offshore 1 motor .... 160mph (gps) at 10 000 rpm ......
deejaycee_2000
hey bond-o ..... that is really interesting .... why would your boat be 11mph faster in saltwater? .......
srt4wad
1977 ArrowGlass with 1985 Johnson 60 VRO and one person I have gotten it to 29mhp.
tommays
You have not had a rush till you pop a 24' dingy on plane surfing over a wave and see the Knot meter break 20
And the roster tail comeing off the rudder is a site to behold :cool:
Tommays
Frugal Floater
18' SeaPro Center Console with 90HP Yamaha 2-stroke... 46 mph with 1 person.
ParallaxBill
My 1973 18' Glassmaster Tarpon tri-hull equipped with it's original L6 165 HP Mercruiser will do 41 mph (gps) @ 4,300 rpm with two adults and half a fuel load on board. The prop is an aluminum 14.5x19.
Plenty fast for me at my age in a 34 year old boat.
JB
My Boston Whaler Sakonnet 16 w/ Johnny 70 saw 90 mph passing slow traffic on I95 back in 1982. :D
bjcsc
Glass-flat water, 62mph, gps, at 4100rpm with 4 on board...
cbavier
deejaycee_2000
Since bond-o didn't answer your question
I'll guess maybe the saltwater has greasy qualities and that's why he?
bond-o says
"Any Grease is Better,..... Than No Grease at All....... "
Status
