Merc 40 Hp 4Cyl won't start
rcb130
94 merc 40 hp 4 cyl 2 stroker will not start. Starter spins motor fine, has spark, primer bulb firm, kill switch is on. plugs are not wet nor showing signs of getting fuel. new ignition switch and external harness. neutral switch checks out ok. Engine was drained of fuel prior to my purchasing it from Army corps of engineers. Any thoughts on what the problem might be?
Laddies
Banned
Re: Merc 40 Hp 4Cyl won't start
Squirt a little fuel in the carbs to see if it will start
AMD Rules
Maybe the needle/seats are stuck closed? Bad fuel pump? Follow Laddies suggestion & toss in some fuel mixture into the carbs to test.
timmathis
Be sure and use pre mix fuel 50:1 or close. Tim
