89 Merc 150 V6 ,stuck!
consie67
I have a 24' CC w/ twin (CR), 89 Merc 150's. These are low hour, good running motors. Today I was running at 1200-1500 rpm on one engine in 4 ft water on mild trim. Water pumping fine. I lowered & fired up other motor and it was OK for a few mins. and then cut out and would not start. At the dock I found that the the flywheel is stuck solid. Motor has NEW impeller and plenty of oil in the tank & line to pump. Any ideas? I heard no noise at all, she just quit. Thanks, Chris
gss036
Re: 89 Merc 150 V6 ,stuck!
I think I would pull the spark plugs and see if you can turn it over. Will it go into neutral? If so should have free spin w/plugs out. Try tuning the prop by hand, make sure you have the plugs out so it will not start.
AndyL
Put the Kill switch down too so you dont get a HT shock should you be touching a lead accidentally.
consie67
Thanks, I will try that but it does go into neutral & the prop turns freely. I cannot move the flywheel by hand in neutral or F & R. I'll take out the plugs & let you know. Thanks, Chris
wilde1j
I think I would start by pulling the LU off to determine if the PH or LU is bound up, then proceed from there.
thespearstn
if it broke a ring you shouldnt be turning it at all. i done that and ruined my cylinder
