Re: Mariner lower unit oil change
Welcome to i-boats dcjfam1. The best boating forum on the web IMHO.<br /><br />Bottom plug is drain/fill. Upper plugs are both vent plugs in reality. Remove all of these plugs when filling. Fill L/U from the drain/fill plug hole until oil flows from front vent plug. Without removing the tube of lubricant, install the front vent plug and then continue filling until it is level with the bottom of rear most vent plug. Install the rear vent plug, remove the tube of lubricant and install the drain/fill plug.
