shock from control box!!
Gus Mortimer
Alright this is a 1982 L6 90horse with the comander control box.<br /><br /> I searched a bit but couldnt find this one. <br /> When starting the motor I simotanously touched the little bit of crome on the throttle lever and the window frame and got a nice little jolt, like from a spark plug?? <br /> I looked at my wiring diagram but couldnt see right off where ignition voltage could come back to there from. <br /> Anyone got any thoughts on this? Oh it only happens when I ground myself to the window frame.
Re: shock from control box!!
There is a large post in the electronics board @ this same item may help. Good Luck
Gus Mortimer
bump, and also this is only noticeable just before it actually fires then no more shock.
Gus Mortimer
so in another post I was reading that the black/yellow wire going to the mercury switch was grounded wrong on someone elses motor causing this problem. I dont think my wiring harness has been tampered with. I have not checked internals of control box yet. I did however unhook the mercury switch (black/yellow) and I no longer got shocked but when I tried to shut it off, it would not turn off using the key. is this normal?
h7
for a quick fix on my 90 i just put a toggle switch inline to kill the motor
