leaking prop
boatybum
i have a 99 15 horse 4-stroke leaking oil from the prop. is this a bad seal or what?
KCLOST
Re: leaking prop
What color is the oil? Black, or brown like lower unit oil...
boatybum
Re: leaking prop
besides, what would the black oil indicate anyway???(just in case)
eurolarva
Re: leaking prop
First verify you are getting water in your lower unit by removing the drain plug and cheking oil. If it is white or water comes out you have a leak. If this is the case you are problably leaking oil from the bearing cage and it will have to be removed and a new seal purchased. If the oil was black it might just be carbon from the exhaust leaking down on your prop. This is probably not the case because this is a four stroke and black oil would be two stroke oil mixed with carbon.
boatybum
Re: leaking prop
one other question, water sputters out of the exhaust also. is this normal???
