Help - water in the oil
ahsah
I have a Larsen 1998, with a 4.3 Volvo 190hp carberated ( didn't see Volvo forum so I'll ask it here). When it was winterized last fall the drain plug on the intake manifold was missed, and I'll assume it is cracked. <br /><br />I put it in the water today and I noticed gas smell after ran it at idle for awhile. I checked the engine compartment and nothing seemed wrong. I ran it a at 3/4 throttle nothing seemed wrong but it would cut out at full throttle. <br /><br />I opened the motor cover and the motor was covered with the milky brown oil/ water mix. After I loaded it I checked the oil and it was also coated to the top with the same sludge.<br /><br />I went and got several 5qt jugs of oil to change the oil tonight several times. I forgot about the oil filter though, I'll have to pull it and empty it between oil changes. <br /><br />What damage might I have done to the engine other than the Manifold crack, and what other things might I do to try to save the engine? Is all this necessary - or might the oil changes wait. I'll have to briefly run the engine between oil changes tonight for a while without it being on the muffs. <br /><br />Thanks for your help.<br /><br />Steve in Iowa :(
ahsah
Re: Help - water in the oil
Here it is 5:30 in the morning and I have been up all night with the boat. <br /><br />First I pulled the belt off the water pump so wouldn't burn it out. Then went back to Walmart and bought the three oil filters they had for a a 4.3L chevy. <br /><br />The sludge of water/oil was too thick to draw out through the dipstick hole. I pulled the plug on the oil pan and let it run into the bilge, which already had about an inch of the sludge in it. After a couple hours of draining sludge, I put in a new filter and 5 qts of oil. And I ran it until the engine started to overheat -about 10 minutes. <br /><br />Repeated the draining of the oil/water and let it cool and drain again after 2 hrs. I put on a new oil filter and another 5qts of oil and repeated what I did before. <br /><br />I did this a third time and the oil is now coming out like milk and finally very runny. <br /><br />The oil is $4.87 (5 qt jug) and the filters are less than $2. I figure I'll have to do this a few more times to get the oil looking right. <br /><br />Then I get to look forward to the tear down for the Intake manifold- any one have a good source on one?<br /><br />Of course I had to do all of this at the Boat launch so I wouldn't wake the neighbors here on the lake. <br /><br />Steve in Iowa
rickdb1boat
ahsah <br /><br />You will get faster and better results if you post in the "I/O or Inboard Engine Repair & Questions" section. This is for Merc outboards and many here may not be able to help you as well. Try re-posting here:<br /><br /> Post Here
ahsah
Sorry for the off topic post. I missed the "out board" part :) <br /><br />Went down the list looking for Volvo didn't see it it so I just picked a section.<br /><br />I'll move the post to the I/O section.<br /><br />Steve<br /><br />Moderator it is ok to delete the post if you sodesire.
