harleyman124
Thread starter- Joined
- Apr 1, 2004
- 8
1987 Mercury 8hp..tan ooze coming from idle exhaust ports (both holes) and very smoky. It idles fine, but when revved up it smokes badly. The top spark plug is wet, the bottom one is dry. I swapped the coils but got the same result on the plugs. I adjusted the idle screw, have new gas and the right ratio mix. The reeds look good too. The water pump is working fine...its a little slow to pump initially, but works good once it starts flowing. Any ideas?<br /><br />Added..I have pics of the ooze
