NO SPARK
sitimortlab
I HAVE A 25 HP MERC ENGINE AND KNOW VERY LITTEL ABOUT IT.ITS ELECTRIC START AND TURNS OVER BUT I HAVE NO SPARK.THE SERIAL NO. IS OA946482 AND ANOTHER NO. FOUND IS P/N 3397452A7 . TO UNDERSTAND HOW TO TEST THIS I NEED TO KNOW WERE I SHOULD FIRST GET CURRENT FLOW TO START THE ELECTRAL PROCESS. AND IF THIS HAS POINTS AND IF SO WERE WOULD I FIND THEM.
WillyBWright
Re: NO SPARK
Electricity is produced by magnets in the flywheel rotating around stator coils under the flywheel. There is a trigger coil under the flywheel that sends electrical pulses to the switchbox which is located on the side of the block. The switchbox takes the electricity from the stator and sends it to each coil based on the pulses from the trigger. The coils boost the voltage to fire the sparkplugs.<br /><br />You need something called a DVA multimetermeter to test the switchbox. Only place you can get one that I know is a Merc dealer and few stock them for sale. You can test the stator, trigger, and coils with a conventional multimeter. Manuals are available in a wide variety of places, possibly including your public library.<br /><br />For most other brands, it's a matter of elimination. If the stator, trigger, and coils check out okay, then it can be assumed that the switchbox is bad. The same logic would apply to yours.<br /><br />One often overlooked simple solution is the lanyard kill switch on the remote control (if yours has one) or mounted to the motor itself.<br /><br />One quirk with those motors...if you get a DVA multimeter, you might have to switch the red and black leads to get a reading. Many of these are polarity sensitive and need to have the polarity reversed on the tester. Just certain 18/20/25s. Doesn't apply to the rest.
sitimortlab
Re: NO SPARK
thanks for this info you have described this well .now if i can figure out which parts are which i should be able to locate the problem.is there a way to get a scematic over the net on this motor .i now have the model no 7025226 and the year is1986
