86 Mercury Starts but won't run, HELP ME!!!
Rock Man
86 Mercury inline 6, was out on boat today, was running fine stopped for lunch, came back to boat tryed to start, fired up but won't run longer then 2-5 seconds, checked fuel filter, replaced spark plugs, same thing fires up but won't run, after 4hrs I finally got towed back to ramp were I doc... got home Charged batteries tryed again, still same thing, fires up but won't run, getting plenty of fuel and spark... Don't know what's up. Please!!! HELP!!!
hondon
Re: 86 Mercury Starts but won't run, HELP ME!!!
First of all you should consider doing a compression check.You will find that this check is difficult on the bottom cylinder , but it can be done. Compression should read 120 or better on this animal but you are really concerned with how close those reading are to one another.Will this engine continue to run if you choke it?
captsara
Just for fun,<br /><br />If I was stuck at sea with your delema, I would, first check all my fuses. Paying special attention to fuel pumps, and or electronic ignition. I would turn of my battery switches (engine off of course). And check all my fuses, cleaning them up as I go. If my boat had breakers I would turn them all off and on, checking for mushy ones,and check the back of the panel to look for bad conections. Tightening screws and changing fuses only at this point, unless I found something bad.<br />If that didn't help I would head for the bilge and folow the fuel line every inch of the boat till I found the air leak. Paying special attention to the intake manifold, hoseclamps on filters, and those nasty brass fittings that love to crack. <br />Does your boat have a mechanical fuel pump, or electric, or both.<br />I like to start at the engine and work my way back to the tank, although it's kind of fun to take the fuel line off the fuel tank side of the first filter in line. I Blow in it and see if I hear bubbles, just in case there is something in the tank. Blowing in a fuel tank is probably unhealthy and dangerous, deffiniatly a no smoking event. Good Luck!
zatoichi
No offense meant by this suggestion, but I had a very similar problem and was tearing things apart and ready to give it to a high priced mechanic when a friend suggested I change out my racor. To my joy and some embarassment, it fired right up and never gave me problems again. I say "no offense" because it seems simple but I never thought of that even though I thought to check the fuel filter on the engine itself. Good luck.
chumbucket
ZATOICHI WHAT DID YOU MEAN WHEN YOU CHANGED OUT (RACOR) ??? THANKS
Rock Man
RACOR ??? Help me here!
chumbucket
ROCKEY RACOR??????????
rbu
Racor's are a brand of fuel filter.<br /><br />Have you tried running the engine off of a 6 gallon tank? That's a good way to isolate a fuel problem in the main fuel tank or fuel lines. Have you checked your priming bulb? There is a check valve in there that can screw you up.
Rock Man
ya I tried to run her on another tank, still samething, runs for 2 to 5 sec and quites, shuts right down, Like I shut it down...
Rock Man
Ya! have plenty of fuel comming out of carbs, Gearcase oil looked good was going to replace this spring, won't stay running long enough to put in gear... Going to do stator test, switch box test, ignition coil test tomarrow. Do you think it could be one or more of these or am I wasting my time? Just was hoping that it was something simple. Not my luck. Never got into under flywheel stuff before but am willing to learn. Still have samething, starts up but won't run longer than 2 to 5 seconds... Sounds good when it does run to this point. Has me stumped big time.
Backlash
Hey Rock,<br />After you do the compression check, concentrate on the fuel delivery system. Start at the tank & work your way to the carbs. Clean tank? Fresh fuel? Tight fittings? Good primer bulb? Clean fuel filter? Fuel pump diaphram good? Clean carbs? <br />Backlash
Rock Man
ya backlash, I already done them all!!!
Rock Man
Sorry for Double post... New at this!
Rock Man
Thanks for input, Checked compression<br />1 is 122,2 is 128,3 is 128,4 is 122,5 is 122,6 is 120 deffently needed hose todo this one, won't start with chock, makes worse, already checked fusses, replaced all gas lines, blowed in tank does bubble, pumped all gas out and replaced with new high octain, disconnected line to carbs then turned over, pumps gas out hard, has 2 fuel pumps... still samething starts up but won't run... runs only for about 2 to 5 seconds... I don't know what eles to do...
Backlash
Hey Rock,<br />Have you cleaned/rebuilt your carbs?<br />Backlash
Rock Man
no haven't done anything with carbs... was hoping it was something simple.
chumbucket
RBU THANKS FOR RACOR INFO
Backlash
Hey again Rock,<br />JMHO but it's a fuel problem. If you've checked everything else, it's time to go through the carbs. You've got good compression & good spark.....gotta be the fuel. ;) <br />Backlash
MURX
bypass the ignition switch(maybe a bad switch), does it stay running if you pump the prime bulb? if you have a spin on cartridge type fuel filter check the gasket on the filter
