Hi all,<br />I have an 84 65hp evinrude. The steering is stuck in the mount bracket. I have the lower unit and mount bracket off the engine but I can't get the arm out. If I use a lot of force I can turn it partially side to side. There is a lot of corrosion on the inside of the arm. I have tried using a mallet, a prybar, heat, and penetrating oil with no success. I'm pretty sure I have all the bolts out but maybe I'm missing something. Any suggestions? Thanks.
