pursuit2460
- Aug 24, 2004
- 193
I was checking all of the engines hoses to make sure that none of them are clogged or are leaking. I found what looks like a check vavle in the bottom of the engine. It has a hose coming from the very bottom of the engine then this check vavle and then a hose going to the very top of the engine. I took out the vavle and i can blow though it both ways is this normal or am I only suppose to be able to blow one way. Im thinking its not since the valve has an arrow on it that was pointing towards the top of the engine. thanks
