rolmops
- Feb 24, 2002
- 5,751
While working on a 1993 9.9 johnny I damaged the piston connecting rod #0396607.It goes from the crankshaft to the piston.I have another one off a 1975 9.9.(# 0385964)<br />Checking the the interchangability I came up with the following.#0396607 replaces # 0385964.<br />Ok so I can use a 1993 one on a 1975.There are a few differences.While the '75 has one hole on the cap and the piston end,the 1993 has 3 holes on each end,presumably to allow for better lubrication.Also the '75 has the piston wristpin needles in a housing while the '93 has no housing.<br />This being said,the question is,can I use the earlier 1975 piston rod in a '93 engine as is or must I drill additional holes in the bearring cap and wristpin end or must I get the 1993 and forget about using a 1975?<br />As always,thanks for your help and opinions,Rolmops
