Is there a way to flush out the water passages of an engine that won't run? 115 johnson.
G GatorMike Ensign Thread starter Joined Aug 3, 2003 Messages 902 Dec 14, 2005 #1 Is there a way to flush out the water passages of an engine that won't run? 115 johnson.
A andy6374 Lieutenant Commander Joined Aug 4, 2005 Messages 1,617 Dec 14, 2005 #2 Re: Procedure to flush a non running engine? drop the L/U, take out the tstats and stick a hose in the tstat hole. See if anything falls out the water tube.
D deeep water Petty Officer 2nd Class Joined Nov 20, 2005 Messages 178 Dec 23, 2005 #3 Re: Procedure to flush a non running engine? i too would remove the tstats,,but i would ust the water ears and turn the moter over by hand,,or by 1/2" drill moter to the fly wheel ,, remove the spark plugs to ease off the compression
