Re: what rpm should wot be on a 1993 70 evinrude
Boat weight and/or design has nothing to do with the correct WOT RPM...doesn't matter what it's on, the RPM I listed above will allow the engine to opperate efficiently at any RPM below that, on any boat.<br />That RPM should be attained with a normal load as well, whether your normal is 6, 350lb guys or 1 200lb guy, it has to be set-up for a specific RPM for your normal load.
