25hp Evinrude Year?
fishingguy
I have a 25HP Evinrude (Model E25RLCDC) and I need a new propeller for it. I am told that I need to get the year. I think it is a mid-to-late 80's model, but I'm not sure.<br /><br />What year is it and what kind of prop do I need?<br /><br />Thanks.
CATransplant
Re: 25hp Evinrude Year?
The kind of prop you need is going to depend on what kind of boat it's on. There's no single "right" prop for that or any outboard.
fishingguy
Thanks a lot. Just out of curiosity, how did you know that it was an '86?<br /><br />Also, the boat is a 14ft Starcraft aluminum fishing boat. Nothing special. I realize that you can different pitches/diamteters, etc., but I was more worried about getting the right fit (# teeth and so on). Any help?<br /><br />Thanks again.
CATransplant
There's a chart at marineengines.com that deciphers the code on those engines.<br /><br />As for the prop and splines, etc., I don't know. Your engine is a lot newer than mine and I don't follow that stuff. You can use the prop finder right here on iboats (click Props up on the top of any page) and get a list of props that will fit your engine.<br /><br />I wouldn't venture a guess as to the right pitch for your boat. It depends on so many things. What's on the outboard now?
martinphantom
The timing is weird. I too have a starcraft 14' boat with a 25 hp johnson(same as evinrude I think). I'm looking for another prop also. Mine currently has a 10x13 and runs very good(when I'm in the boat solo)-but I thought about buying a different pitch just to try and compare the results(when another 200+ lbs is added then it doesn't want to get up and plane out). You'll get no suggestions on here without a tach reading. I looked at props on this page and all were 10" props with varying pitchs.
