1982 Evinrude 35 2 Stroke Stopping
Status
Not open for further replies.
Dr Dean
Re: 1982 Evinrude 35 2 Stroke Stopping
I think you are correct. The oil that I saw leak out was black while the gear oil is "normal" color. I've been watching the gear oil closely to make sure I'm not having a water leak problem, and so far it looks good. My early contamination may have just been due to rain getting in while I had it apart. I flushed the gear box out with gas three times to and examined the waste to ensure that I did not see gear shavings.. so far so good.. Thanks for the help..
Dr Dean
I have my boat running well now. It seems to have about the power that is should on my 16 foot boat. However, as it gets up to speed and the load on the prop decreases, I hear a pinging noise that is rather noticable and seems to be coming from the top of the motor. I've pulled on the pull start (it is an electric start) to see if it could be the clutch mechanism that is mounted on top of the flywheel. I pulled on it while the motor was running and the pinging persisted as usual. The noise sounds unsusual to me. I DO have the correct fuel/oil mixture and the carborator is adjusted 1 1/4 open as per the instructions on the carborator housing. Any suggestions as to what this noise may be? I'm looking for something under the flywheel that may be the source of this pinging. It sounds as if it is something metal to metal. Thanks in advance for your ideas.<br /><br />dean
edclarkson432
Hi I have a 1965 evinrude 18 hp twin. The engine starts but wont stay running unless I pump the bulb continuously. i have no knowledge of boat motors, be basic. Thanks Ed
Bosunsmate
Hi Ed this post is from 2005, its stale!
You need to start a new post with a new heading.
oletrout
Have an issue with a WC1 Neptune 1.7 ( Tillotson Carb)... starts great when on a test stand with no water...as soon as I put it in the barrel...will not start,water is about 2 inches
above the anti cavitation plate!! ?? HELP
GA_Boater
Start a new thread after reading the Help Tip on top of the page. This thread is 12 years old.
Closed.
Status
