one problem after another.............
ross patti
After 4 months trying to fix an electrical problem[done with the help of the iboats gurus],my 35 Johnson went perfectly on it's 10 mile test trip.<br /> The following Sunday,we loaded up with live bait,fuel,snacks,etc and left at 4.30am for the 60 mile drive to the river.<br /> The forecast of rain looked unlikely as we slid the boat off the trailer.I eased into the captain's seat and turned the key.<br />Not a sound.Being the inquisitive type,I turned it again.Still nothing.<br /> After checking :battery,leads,starter motor,ign.switch,etc,etc,etc, we finally gave up after 3 hrs of checking.It ran fine 3 days ago,and now was dead.<br /> The trip home was pretty quiet;morbid,even.We took it to my brother-in-law who is handy with such things.After 2hrs,he isolated the problem to the neutral starter safety switch.It had power to it,but no ground from it.He was certain this motor should NEVER have started.Without the ground lead,it should not work.The only answer was an accidental earth leak thru the lead.<br /> Whatever the reason,the motor now started.<br /> The Pig-headed fisherman in me said..."It's only 11.30,let's go fishing closer to home"....In the words of Homer"It's still good,It's still good !!!"<br /> As we slid the boat off the trailer again,My thoughts drifted off to that nice little insane asylum down the road...<br /> This time,when I turned the key,it started.Brilliant !!<br /> After 10 seconds,it started to die.By the time I reached the tank to release the air valve [which was released]the motor died.<br /> Ten minutes of trying to start it only made it worse.There was fuel peeing out all over the place.It looked like the fuel pump was just dumping the stuff in the engine.<br /> After 20 minutes of frantic paddling,we finally made it back to the ramp.Everyone around looked amused as we put the boat on the trailer, again !!<br /> At the bottom of the leg,there was fuel leaking.The top of the motor had fuel leaking.It smelled like a refinery.<br /> At home after another long,quiet drive,I discovered the problem...<br /> A bolt at the carby Was the wrong length.It had worked it's way out about a quarter inch,and was now holding the choke linkage open permanently.Yes,I put it in,so I can blame no-one else.<br /> I hope I've used up all my bad luck now,and I trust you had a chuckle reading about" Black Sunday "
fireman57
Re: one problem after another.............
Good to hear from you again mate. Just wish it was better news. Don't give up on the old donk. Sounds like you're getting all the bugs worked out so the rest of the autumn will be pleasurable.
ross patti
Hey,fireman...<br /> I kind of hoped you would drop in.Hope you're keeping well.<br /> Can you believe that trip ??.Two distinct,yet lethal coincidences in one go.<br /> Once I freed the linkage,we started her up and let her idle for about 5 mins. without a problem.<br /> My bro.in law was convinced I pulled the earth wire,and didn't want to tell.<br /> On another issue,do you think it's a good idea to put "sea foam" thru the motor?<br /> Even though the compression is good,I'd reckon a good clean would do it wonders.<br /> Till next time,take care,mate
fireman57
Yes, it'll keep the carbon out of your cylinders and help keep the carb clean.
papa_Lazerous
well at least you havent got any cut wires under the flywheel this time, you'll get there in the end.<br /><br />sometimes things just happen
ross patti
I like that quote,John. I might get it put on a sticker in the boat..."sometimes things just happen...."<br /> Thanks for dropping in,hope all is well.<br /> I think I'll put some in fireman,over here they call it "engine tune "<br /> Till next time guys,take care
Marauderk
Wow you sound like you have my luck :) And seafoam did wonders to my old evinrude the thing idles better now than when my grandfather bought it new.
ross patti
Hi everybody,...<br /> For those interested,we took the boat out on Friday,and it went perfectly.<br /> We even caught some fish !!!<br /> Will put the Aust. equivalent of sea foam in during the week,and let you know of the results .<br /> Thanks again,till next time....
fireman57
Sounds like you had a better weekend than I did. Went for 3 and a half days and we only caught about 20 fish. Cold front came through and rained like hell.
ross patti
Hey,fireman...<br /> the engine is running like a treat !!<br /> I guess at this time of the year,you are getting out of the cold,where we are just getting into it.But I hope your trips improve soon.<br /> The "engine tune "should be in soon, i'll let you know how it goes.<br /> Take care :)
fireman57
Thought it never got too cold in sunny Australia. Things are just starting to pick up here. Long cool spring. June should let everything bust wide open.
