starting problem when motor is running.
letsbarbq
hello to all again. it has been awhile.<br /><br />motor is a 98 johnson 225 oceanrunner. i mix my own oil. i would run it for a hour or two. then when i shut down and then start up about 20 mins later. it will be hard to start and then bog down when i go into gear. <br /><br />i do notice that it is about 5000 rpm when i put it in gear. <br /><br />to get me out of this situation. i would start it and then rev it up in neutral and let it do it for a few secs. then when it would go back to normal operation.<br /><br />what can it b?]]\\\<br /><br />i got water pressure gauge and it show good. but i do not see much shot our of tattle tale?<br /><br />is my idle low? i might be mixing too rich. could this be a factor or can it be a fould plug?<br /><br />my fuel is clean too. and i got all spark.
papa_Lazerous
Re: starting problem when motor is running.
reed valves maybe....<br /><br />whats everyone else think?<br /><br />has the engine been sat for any ammount of time?
Silvertip
What mixture are you using? If you suspect the plugs are bad, remove them and check them. Yes, the wrong fuel/oil mixture can affect peformance. So can carbs that need rebuilding.
