I just bought a boat with a Evinrude 1998 OceanPro 175hp 60 degrees 25" engine with a damaged lower unit. I located a good similar lower unit from same angine type with exception that it has a 20" shaft and shiftshaft. How dificult is to remove my 25" pieces and installed in this new lower unit?. There is any special procedure to follow? Is the Shiftshaft screwed in?, do I have to count turns?. Any help will be appreciated.
