91 Erude 60 hp runs great out of water not in
Limabravo911
It runs real good on dry land with a water wing.When I put it in the water it dosen't sound right, and dies when I put it in gear. I have checked all fuel lines, and even rebuilt the carb,s, but still have same problems. It was running gret then died on the lake one day, and ran like it was bogging down. Thanks for any help...
Limabravo911
Re: 91 Erude 60 hp runs great out of water not in
No I haven't but I will. Pretty new to this I will check it out thanks...
fireman57
You probably need to set your idle in the water. If it bogs squeeze your primer and see if it picks up. If it doesn't then check for spark when it bogs.
Solittle
Check to see if your are getting a spark that wilol jump a 1/2" gap with a bright blue snap. I suspect though that you still have some crud in the carbs.
Cricket Too
Lima....Your compression should be within 5% on all 3. If it's good and your spark tests good, I wouls have to agree with SoLittle, and would pull your carbs again. Did you do a Link and Synch after you put the carbs back on?
cvx35
3 carbs... pull 'em back off...take the 1/4 inch standard threaded slotted 7/16's head bolts out of bowls...Get a skinny screwdriver and take the jets out...Use a torch head cleaner to clean them...And soak in carb cleaner...Reassemble...Drive on
cvx35
Could be a number of other things though...compression...carbon buildup behind rings if it ran ok to begin with....engine warms up, pistons swell up...engine overheats...you bog down after engine overheats
cvx35
get a buddy and a screwdriver to check firing at your own risk....
Limabravo911
Thanks everybody I will get started on everything, and keep yall posted.
Cricket Too
I would advise getting a real spark tester from an auto parts store they're cheap enough and easier.
