Carb rebuilding?
leatherneck46
Rebuilding the carbs on my 1968 65hp Evinrude Sportfour. I've got an omc manual but seems alittle vauge. Talks about leaf valve assenble but I don;t see it. Any one know of a tutorial for carb rebuilds. I talk with the machanic and he said not to soak the carbs in anything "omc recomended". How do u clean all the passages?<br />Thanks
chris in va
Re: Carb rebuilding?
I was recommended non-chlorinated carb cleaner, then take some fine wires to clean out the small passages (on my 9.9 anyway). Then just blow them out with compressed air.<br /><br />I believe the leaf valves you are talking about are actually inside the engine.
leatherneck46
Thanks Chris in va<br />Anyone else have an opinion with requards to cleaning passages or a video tutorial. How abou those leaf assembles? Where r they located.
rwcreigh1
try carb spray and compressed air to blow it out
leatherneck46
Leaf assembly. In my manual its in the carb rebuild section. Wheres it located..
BillP
These carbs are easy to work on but get a better manual. "Leafs" are located behind the carbs and carbs come off first for access. It's the last place I'd look. I don't think your carbs have fixed jets. That means you can unscrew the adjusing needles and get to the jets without taking the carbs off. First thing I'd do is drop the bowls and check for crud. Then clean and blow the jets out. Actually I think the needles just go into a seat for adjustment. Pro ob guys will chime in and know for sure.
