Re: '84 150 hp, lower unit question
Thanks guys, I got the pin out just before dinner. It sure made dinner better. There is a small plate under the bottom carb (air entrance), made out of cowling material that looks like it is just there for air deflection. It only has three bolts in it. I took it off, and it made getting to the pin alot easier. <br /><br />OBJ, it was easier to reach when it was in reverse, that pushed the pin forward. <br /><br />I'm sure I'm looking at a major overhaul on this motor. Never done one before, but since I don't have much money in the motor, I thought I'd give it a try. The motor hasn't run for over a year and it's "froze up" I thought among other things, when I dropped the gearcase, I'd be able to replace the water pump and tell what was "froze", I pulled the spark plugs out and thought I should be able to turn the flywheel by hand if the powerhead was ok. it doesn't turn. I'm also thinking if the lowerend is ok, with it off I should be able to turn the driveshaft by hand, it doesn't turn either.<br /><br />Is my thinking correct or am I all wet before I even get the boat in the water. <br /><br />Thanks again,<br />Big tater
