Repairing Stripped Screw Holes in Fiberglass
Angler276
There are several places on my boat where the screw holes have become stripped out and the screws are no longer doing their job causing a very rattly ride. What is the best way to remedy this. Do I use anchors or fill the holes with some kind of putty or cement? Thanks a lot!
Boomyal
Re: Repairing Stripped Screw Holes in Fiberglass
Depends on where the screws are. If you can, I'd use machine screws and nylock nuts.
rwidman
Originally posted by Boomyal:<br /> Depends on where the screws are. If you can, I'd use machine screws and nylock nuts.
If you can't get behind to use nuts you can fill the holes with epoxy and then redrill them and reinstall the screws.
jtexas
replace 'em with bigger screws.
tengals123
Master Chief Petty Officer
fill em and redrill em!<br />cheers
dajohnson53
If you haven't used JB Weld, this is a very strong epoxy. There's probably equally strong epoxies, but I've used it quite a bit and am very pleased with it. I would guess that if you filled the old holes with this and re-drilled, it would be strong or stronger than original. Assuming, clean, dry hole, of course.
Billnicole
Plastic Mollys work good too :D
