Recoil starter interchange
Ronald1
I have a 1955 Johnson CD-12 5.5 hp. The bracket that holds the recoil starter mechanism is cracked around the center bolt hole. I found a complete unit one E-bay that came off of a 1955 7.5 hp. Will this unit fit my 5.5 hp. All I realy need is the bracket. Thanks
Chinewalker
Re: Recoil starter interchange
Hi Captain,<br /> Yes, the '55 7.5 Evinrude recoil will work. They changed them significantly in 1956, as they went to a larger flywheel, single pawl on the recoil, and different footprint for the mounting legs. Yours is the same for 1954 and 1955 model years... In other words, if they look the same, they are the same - there's no confusing a '55 with a '56 recoil...<br />- Scott
Ronald1
Thanks for the info. It looks exactally like mine. Bought it on the "buy now" for $10! Thanks
