teflonharry
- Jul 23, 2004
- 25
Hi!<br />My motor runs only on 3 cylinders one is lost.<br />Top starboard does not work.<br />THe carbs are cleaned.<br />I have checked compression. They are all between 105-115 psi. There are a spark on all 4 new spark plugs.<br />The cylinder gets gas. I have switched ignition coils between the running and not running cylinders. I have switched power packs (CD's) and still the same cylinder does not work.<br />I removed the flywheel and found a CRACK and some melting in the plastic of the stator.<br />CAN this be the problem? I checked the resistance between brown and brown/grey cables from the stator to 570 ohms on both pair.<br />There was a short circuit (0 ohms) between the yellow and yellow/grey from the stator.<br />What are these yellow cables used to?<br /><br />Anyone have any idea how to check the stator? or what can the fault be? and how can I find out what is wrong?<br /><br />Just to check. Should each ignition coil be connected to the closest sparc plug?<br />/Harry
