What's the difference between.....
MarkHPCA
an '86 120 looper and the same year 140 HP? The 120 I believe is a 1.8 Ltr. Do they have the same lower unit ?
jimmbo
Re: What's the difference between.....
20 hp. Both use a 1800 ml block and both have the V6 gearcase.
Dhadley
They have the V6 STYLE gearcase but a different ratio than the standard V4 or V6. The basic difference in the motors is in the induction area.
MarkHPCA
So..... if I wanted to convert my 120 to a 140 what would I need, different carbs, reed blocks ? How about timing? Anything else ? What would be the effect on the reliability?
jimmbo
Different block, carbs, exhaust tuner, might need a couple of parts on the throttle linkage. Total timing advance should be the same but pickup timing might be different.
phatmanmike
easiest way to CONVERT your motor to more hp, is to replace the decals with larger ones... sorry, but im serious...you cant just swapp out a carb or sumthing and gain a magic 20hp!
D
DJ
Guest
I have to agree with the others. OMC did not make it that easy.<br /><br />The 120 was a solid performer on its own.<br /><br />Tune 'r' up and she'll go great. Prop her for her powerband (5500+ rpm-WOT).<br /><br /> Nice engine.
MarkHPCA
I kind of thought a carb swap was too easy. I can live with what I have for now. Pushes my Hydrostream to 60 MPH with lost of torque.<br /><br />Thanks for the input guys.
Dhadley
Hydrostream? Now we're getting somewhere. Which model?
MarkHPCA
Actually it's a Canadian Edition Vista. This was the CE version of the Valero bowrider, V bottom. Same hull as the V-King but a different deck.<br />
attachment.php
Dhadley
The motor looks kind low. What prop are you running?
MarkHPCA
I have raised the motor since the picture was taken. I am running 2" below the pad, 5 1/2" setback CMC jackplate, with a 24P Raker at 5500 RPM WOT and getting 60 MPH. I don't think I can get much more with this set-up and limited power, remember this is a bowrider so it is a little heavier than the V-King.
Dhadley
Are you running the V6 size gearcase?<br /><br />We need to get the R's up.<br /><br />Is the pad flat or concave?
MarkHPCA
Yes, I believe it is the V6 case. The pad is flat, I re-cored the boat last winter so the pad was well checked then. I can try going higher with the motor but any higher and the water pressure starts to jump around quite a bit as I hits waves etc. At the moment it is faily steady at 29 PSI. How about blocking the top water intake hole on each side? Would this still allow sufficient volume of water to cool the motor?
Dhadley
OK, thats good and bad as far as the case goes. Bad because the larger case = more drag. Good because V6 style props are way easier to come by.<br /><br />Yes you can fill the top two holes on each side. I like to do it by tapping the hole and screwing in a pipe plug. If you do it with epoxy you stand the chance of getting epoxy in the water passage.<br /><br />There is actually enough room at the bottom to add another hole. On one side of the gearcase there is a very small hole that is a drain at the bottom of that chamber.<br /><br />Good catch on the water pressure. It may be time to think about a low water pick up. Lets try the other but start thinking about it.
MarkHPCA
Thanks Dhadley for the suggestions/help so far. How can I tell if it is a V6 or V4 gear case? The one I have is 4" diameter.<br /><br /> I will try plugging the top holes and raising the motor some more to see how it goes.
Dhadley
Are the threads for the prop nut fine or course?
MarkHPCA
The outside diameter of the threaded part is 5/8" and there are about 11 TPI, so I guess this is course ? If so is it a V6 or V4 case ?
Dhadley
Fine threads are a V6 style and course is a V4 style. <br /><br />Also if it were a V6 style the Raker would be a 14 1/2" diameter. The V4 Raker is 13 1/2" diameter.
MarkHPCA
The prop is 13 1/2" so I guess it's a V4 case, as you say at least this is less drag. I'll try the hole plugging and see what happens this weekend.
