new tilt n trim for 1976 115 johnson outboard
gty2k2000
is it all possible to get a new tilt n trim for my 115 hp 1976 johnson. the one i have i belive is shot
BrianD
Re: new tilt n trim for 1976 115 johnson outboard
Going through the same thing with mine. My boat had the original on it and I noticed that there is a rebuild kit for it. TR 208. If it is original it was most likely made by Prestolite who was bought by Arco. The ARC pn for mine was 6208.
Gary H NC
Ebay is your best bet.They do make after market TnT units but they are expensive.
Expect to pay about 250 or so for a used one on Ebay.
ezmobee
Gary, I wish you were right. His motor uses the older style (pre-1978) trim unit. They are near impossible to find and when they show up on eBay they go for $400+!!!! I have been looking for over 2 years. However, I don't have TnT at all. Since he has the unit, he probably has a good chance of finding someone that will rebuild it.
Gary H NC
WOW! I didn't know they were that hard to find..:eek:
sergeant285
I had a similar problem with my Calco unit (part are rare and expensive) and I found a guy who has a patented adapter that allows the use of a new design, high-efficiency (and way cheaper) motor, like the ARCO 6206 I bought for $100, with the Calco and Prestolite units. It's an aluminum adapter plate with a steel shaft. Absolutely brilliant. I bought a Calco adapter, and it works flawlessly. I attached a couple of pics below. The adapter is the green-painted section. The guy can be reached at calcoguy@yahoo.com, and he sells the Calco units for $120. If you add the $120 for the adpater and the cost of the motor, it's still less than half what a rebuilt motor costs, and if you need to replace a motor later, it's cheap. Anyway, here are a couple of pics of the Calco unit I bought.
sergeant285
I forgot to say that from the sounds of your post (pre-1978), you have a Calco tilt/trim unit.
