Evinrude 50 No Spark
Diver Dave
Hi Guys,<br />My 1992 ex vro Rude won't start (no spark).<br />It ran fine last season and its just been sat in the front yard over winter.Trim and tilt ok,starter ok,primer solenoid ok.horn ok.<br />Rebuilt the Powerhead 3 years ago due to vro failure, have been running on 50:1 premix since.<br />Had a problem 2 years ago when engine wouldn't rev, disconnected tan wire at powerpack (thanks to Clanton) is he still around ?<br />Ignition/starter switch checks out ok.<br />Thanks in advance Dave
D
DJ
Guest
Re: Evinrude 50 No Spark
Is the kill switch lanyard hooked up?<br /><br />Check for a blown fuse near the starter. It is in a connector that looks like a regular wire connection.
Diver Dave
Thanks DJ,<br />But no tiller no kill switch and the fuse is fine its for the starter solenoid and on a new battery the starter flies like a 747
D
DJ
Guest
Never seen one with out a kill switch.<br /><br />Will it start if you unplug the big red connector? REMEMBER, if it does, you'll have to shut off its air supply to kill it.
Diver Dave
Thanks again DJ but its a Brit model with full remotes and if you mean the big red connector under the cover (main loom) with that unplugged nothing works !
phatmanmike
wrong.. with that unplugged, you get to see what is and what isnt broken.. unplug the big wire harnes plug. get a small length of wire to go from battery to terminal on selonoid with a pushbutton type switch, so you can "bump" the starter.. now start it, or try to at least.<br /><br />by disconnecting the wire harness, you are removing any possible wire problems with either the kill switch, start switch, ignition switch, controls, etc.....<br /><br />by the way, how do you know its a spark problem, did you check the spark with a tester or did you even pull the plugs?
johnny1
I had a no spark problem myself on a Johnson 50 about 3 wks ago. I test fired the motor in March, ran great. Took it to the lake, wouldn't start. Never even got it off the trailer which it turns out was fortunate. Did the red connector test. Pulled it apart, took out the plugs, hooked a spark tester to verify, and spun the motor. No spark. Most likely cause without a crank test to rule out a trigger coil is the power pack. Sure enough, replaced the power pack - all is now good.
Diver Dave
Thanks Guys,<br />I've eliminated everything according to the Clymer manual, except the coils and the power pack, cos I haven't got the kit to check them, I fancy the power pack but trial and error can be expensive if you get it wrong !<br />What are the odds on coils versus powerpack ?
phatmanmike
either or could go, i have coils, working coils from a 1980 50hp..... maybe i can help you... my email is at the bottom
Diver Dave
Problem solved !<br /><br />The black and yellow ignition grounding stop wire had gone to ground in the power pack. (continuity between black and yellow and ground wire from power pack with power pack removed )<br /><br />New power pack on order,should be up and runnong for next weekend.<br /><br />Thanks again for all your help<br /><br />Dave
Diver Dave
Just one more thing<br /><br />Does anyone know the correct part number for this power pack ?<br />The old one is 175316 but the Evinrude dealer says this is listed for a 25hp motor !<br /><br />Engine model AE50TLENJ #G03112133<br /><br />Thanks again<br /><br />Dave
OBJ
Dave....parts break down has it listed as 175316. There was, I think only one model of the 25 in 92 with a power pack. The rest had the ignition module under the flywheel.
Diver Dave
Thanks for that OBJ I just needed confirmation<br /><br />Dave
