FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I have a 1995 88 special that will not always start up right away even after being run for awhile. I just had the carbs cleaned, check the compression, etc. What could be my problem?
Try pumping up the primer bulb again after shutting down and setting a while. If she kicks over, one of the valves in the bulb may have failed and let the fuel drain back to the tank. Also check for lose connections in the fuel lines that could cause air to be sucked in.
Try making sure the ground wire from the battery to the engine block is clean and tight and the ignition wires are the same. Sometimes they look good but aren't actually making the best ground.
MD....was this a problem BEFORE you had the carbs overhauled? Did you also check the sync and link after carb intstallation?<br /><br />Good ID by reeldutch....check the compression. Even if it's OK, you've got a reference for future use. The .040 gap will help the idle.....once you get her running.<br /><br />I kinda' still think it's a gas flow problem.
Compression is good, it could possibly be a fuel problem, but not from the tank to the motor disconnect - everything is new. I will check the gap on the plugs. It also will stall out sometimes when in idle forward or reverse. I dont know if that helps any. Thanks
Yes, Rick once it is started, which by the way could take three to five turns of the key, it runs well except at idle speeds. I do have a choke, all i have to do is push in the key. I am not sure if that is electric or not.
Well....could be a simple sync and link problem for the idle or possibly the idle is set to low which would cause you to stall out.<br /><br />I had a friends 88spl that was doing darn near the same thing. Ended up dropping the idle air jets down two sizes. Didn't have any more cold start problems.<br /><br />MD....by chance did you check the primer to see if it was working OK on cold starts or just flip the red lever to manual and try starting without pushing in the key?
Also, check the low speed settings on the carbs. Lightly seat each idle mixture screw and back them all out 2 full turns and go from there. You could be running lean, which would cause your problem...The lync and sync is a must, if it has not been done, As OBJ said...
"link and sync" is wrench speak for proper synchronization of the linkage between the carbs and the ignition timing advancement arm. Need manual as they are all a little different.
