I am currently running champion QL77JC4 plugs gapped at .040, have correct jetting, new t-stats water pump timing set at 18BTC. Runs great except for extented periods of idling (20-40- minutes)I have a 2mile 5mph no wake zone to get to open water. The plugs start to foul at about 30 minutes , I lift the cold start lever to burn off the excess fuel/oil mixture. Can I go to a hotter plug? I thought I read somewhere here that a QL82YC was used in this case. I don't want to burn up a engine but I would like to Idle. The Idle jet a 30 and is what the factory spec'd. Any advise would be appreciated.
